Follow this link.
The press release:
http://focus.ti.com/docs/pr/pressrelease.jhtml?prelId=sc02062
The datasheet:
PGA4311
Sonny
The press release:
The datasheet:
PGA4311
Sonny
fcel said:What's your question?
I have a feeling that sonny was simply wishing to make the availability of these parts known to people rather than asking a question regarding them.
pga4311
Dear Mr.Sonny,
I have a question about the new pga4311.
Are the buffers really necessary ?
The device seems able to drive 600 ohm loads (from the specs).
Thank you to everyone
Beppe
sonnya said:It would be perfect to do a stereo balanced attenuator with this one.
Perfect match of left/right input impedance .. Minimum left/right gain error.
And than add a buffer to each output and then you have a good preamp.
Sonny
Dear Mr.Sonny,
Beppe
At first. The unit is able to drive 600Ohm as you stated but read the text below and look at the PGA4311 as a opamp the same time.
Taken from Walt Jungs article on buffers for audio :
"These first two installments on high-performance audio with ICs and discretes have focused on choosing (or designing) a buffer stage for best overall performance. In IC op amps with poor thermal design, heavy output load ing can cause shifts in effective input offset, as well as associated linearity changes. These load-dependent shifts can be identified with testing, allowing easier device selection to minimize this problem.
However, simply buffering the amplifier's output with an isolated-package circuit removes this source of error, and maximizes op-amp linearity. This step is recommended wherever it's practical and needed. Buffer circuits can be chosen from a number of ICs expressly designed for such tasks, as was noted last month. Or, they can be designed to match a given set of conditions, as in this example.
And the link for the article :
http://www.planetee.com/planetee/servlet/DisplayDocument?ArticleID=2800
With short cables and a light load there is no need for buffers.
For "tschrama"
"How are you gonna set the damm thing to a certain attenuation... I think the interface in quite impracticle...or are you going to use your PC poort for that.. then try the evaluation board.."
With your words : The interface is damm easy!
You just have to feed it from some micro (Read PIC,AVR,8051 etc..)
The interface is called a SPI interface and there is many applicationnotes on this.
I am going to use a AVR to control it. They can turn the oscillator off. I think i am going plan a project this weekend on this and drop the WM8816. It is a lot easier to get the PGA4311.
For application notes and forums on AVR check www.avrfreaks.net
There have been a thread on the CS3310/PGA2310/PGA2311 some months ago. Try search on this site.
Sonny
For "tschrama"
Sonny
Sonny,
Re:"....this and drop the WM8816. "
Say it isn't so!!!
I was really looking forward to your implementation based on the Wolfson circut. Able to use the op amp (or any inverting amp) of your choice and not constrained by the quality of the internal opamp. I was all a'twitter with anticipation.
You're breaking my heart....
Say it isn't so!!!
Please do not cry!
I cannot take it .... Anyway i have checked the www.wolfsonmicro.com and i have found out that i can buy them online in small quantity.
So i will build both of them! Satisfied!?
I think also that i can reuse lot of the software and hardware in both cases!
Sonny
Sonny
So, my question is, the WM is cheaper, it is nessecary to use the more expensive TI-Chip?
The WM8816 ist to buy under http://www.profusionplc.com
best regards
best regards
Hi!
Check this out, on Ulrich Böhmke's electronics site
http://www.ub-elektronik.de/download/vc-daten-101.pdf
, found on
http://www.ub-elektronik.de/baugr-texte/pre.htm
He uses this IC in his new project, with an LCD-display which displays the volume level...
Bye,
Arndt
, found on
Bye,
Arndt
- Design & Build
- Parts
- PGA4311 ... Yes! four channels
