Peak current delivery measurements on amps.
Dear Sirs,
I read, but I cannot remember where, of a new standard procedure for assessing the max peak current delivery of a car audio power amp.
Foolishly I did not save the link, because I think that this is very important datum that can say how anamp can drive demanding loads (i.e. low impedance and sensitivity).
Moreover I think it would be very advisable that the same procedure should be adopted for evaluating any audio power amp.
Anyone has read that article ?
Thank you so much.
Kind regards,
beppe
richie00boy said:
It should be quite easy.
Drive a square wave or impulse into the amp loaded up and compare output vs input.
Dear Sir,
thank you very much for your kind and valuable reply.
As I said, I found very interesting that after having read how is important this value of the "max peak current" available from an amp someone has gone through the hassle to fix a standard procedure of measurements.
But I cannot find the link again.
Thank you very much again.
Kind regards,
beppe
