PC4100 Problem
I just purchased a used Precision Power PC4100 and it has the oddest problem. The front channels will only seem to play in some sort of pseudo-mono mode. I've plugged my laptop into the amp to make sure the problem wasn't with the head unit or rca's. I've unhooked the speaker wires and put a volt meter on the outputs to make sure the problem wasn't a short in the speaker wire somewhere. No matter what, I get the same problem.
When I try to fade left or right, the volume goes down slightly, but both speakers still keep playing. I'm guessing this is some component failure in the amp itself, although I don't know electronics well enough to find it.
Has anyone else experienced a problem like this? Does anyone know a place to send these old school amplifiers to have them repaired?
Thanks.
