The item previously listed is the DIP version. You probably need the soic version.
Search result for: 5872015 - Future Electronics Ask if it's available in smaller quantities.
STMICROELECTRONICS | TL072CDT | TL072 Series SOP8 High Speed Low Noise JFET Dual Operational Amplifier - Future Electronics
http://www.futureelectronics.com/en/Technologies/Product.aspx?ProductID=LM211DTSTMICRO2124782
Could anyone tell me where i can order IR21844s (14 pin chip) driver chips? I need to repair 10 amps which use the 3s-tech boards plus the smaller chips TL072C and LM211
i need :
40x ir21844s
10x TL072C
10x LM211
anyone have a site i can use for order.
just curious, which amp are these? and, are the chips with the markings ground off are the IR ones?
Thank you Frank, i have actually sent the supplier Perry mentioned an email for getting al the parts from them in one shot.
Thanks, I LOVE THIS FORUM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LM111/211/311 are all the same device just specified for different temperature ranges. See the data sheet.
http://www.national.com/ds/LM/LM111.pdf
Odds are high you can use a 311 if you can't find 211s.
G²
If you don't get a response by the end of the day, email me and I'll give you the email of someone I've dealt with in the past.
babin_perry@yahoo.com
I have finally gotten the parts and as luck might have it gotten 2 brand new driver boards as well. I have since installed new FETS( irfp360LC and IRF064N) and new resistors for the burnt ones. There was sound and i used the amplifier for 2 competitions then it started giving hassles again. Changed the muting transistor that runs down the middle of the board between the power supply card and the transistor drive board . after awhile that failed as well. Now the amplifier switches on but there is no sound, i have changed the transistor again but to no avail. any hints on getting this problem sorted?
- General Interest
- Car Audio
- parts
