For Sale Parts for Dual Mono M2x Amplifier and other goodies (Includes Edcor Transformers)
Things you have for sale.
Unfortunate work circumstances force me to sell of some DIY parts. I am selling the whole setup below for $325 shipped Conus. I did a rough estimate and sourcing these parts brand new would put you around $450. Keep in mind I only have the 3 pairs of daughter boards.
Here is everything you get. Keep in mind some parts have been used, some brand new, and the m2x boards untested.
  • Two Triad VPT36-4440 (2x18VAC 160VA) Transformers (USED)
  • Four diode bridges using MBR20200CT (USED)
  • Two Power supply boards with 60,000uf per rail and CL-60 installed for GLB (USED)
  • Two M2x boards with 6l6's DC offset modifications (NOT TESTED)
    • Edcors installed with Copper Strips
  • Three Daughterboards - Norwood, Ishikawa, and Cedarburg (BLANK)
  • Set of Gold Plated Binding Posts (NEVER USED)
  • Unmatched set of IRFP240/IRFP9240 Mosfets (NEVER USED)
  • Pair of Gold Plated RCAS (NEVER USED)
  • XRK's Daughterboard testing PCB (NEVER USED)
  • Mu Metal to cover the Edcor Transformers (to shield the Edcors)
  • Spade connectors for the M2x boards and the diode bridges
Some of these parts will show wear from storage or use, but I can guarantee the diodes and PSU's work perfectly. I replaced all of these parts with SLB boards which is why I no longer need them.
Reactions: STOXX and birdbox
