Parasound HCa 1000a
The repair tech stated the amp is in pretty good shape and the problem with the channel was the two fuses and he replaced them. The only suggetion he recomends is some of the 12 resistors (.33/3w) need to be change. so rather than just changing the (4) just change all of them. He stated that h ewould just cut the leads on the existing resistors and just add the new ones, that way he does not have to take the amp apart. What .33/3watt resistors would anybody recomends. Stay with the same (no brand on them they are just ceramic) or what would be better some one mentioned mills.
Please help
I did the same thing on one of these amps a couple years ago. I think John Curl himself recommends that, although may not be recalling that correctly. I used 5% Sfernice thick films from Newark. To be honest, I sold that amp before things got burned in and I did so much other work on it I can't offer an opinion on the sonic quality of the change. It also doesn't help that I didn't care for the amp (you gits what you pays fer and I think I paid $100 for that one...) John himself said the amp was designed and built for a low end price point.
Mills would be good but at 3W they may not fit cuz aren't they big? Also, I would feel better if the resistors were replaced the "normal" way rather than the "easy" way.
It is tricky to test them right. Did he unmount them to test? I think you said he want to " just cut the leads on the existing resistors and just add the new ones, that way he does not have to take the amp apart." He needs to unmount them or cut them to test exact value of each resistors because insulation sleeves, old soldering rosin, oxidization, attached parts etc....
I would still leave them alone. At least, try it, as is. It is difficult to get a precise reading without taking them out, and even a +/- 20% variation would not do much, IN THIS AMP, because the value is so large, virtually twice the JC-1's resistor value, and different values actually help make a smoother transition from class A to class B. The BEST thing to do is to operate the output stage with as much current as possible, before over-heating the heatsinks, and they should run very warm to the touch or 50 degrees C or so.
