I was planning on buying a midrange speaker along with a tweeter. I was told that if I hook a 2uF capactior from positive of the tweeter to the positive of the speaker, the tweeter will be rolled off at 10 khz, at 6db/octave.
Does this mean that the tweeter/speaker combination would be wired in parallel? Both are 4ohms and my amplifier has 2 channels that needs no less than 4ohm per channel. By wiring the tweeter and speaker with the 2uF capacitor, would they end up being 2ohms? If so, is there a way to avoid this?
Thank you for any information
