It depends on how well matched the devices are. A good starting point would be something in the range of .33 to .51 Ohms. If they're completely random, you might consider going as high as 1 Ohm. Obviously, lower is better, but it's more money and more work. The better matched your MOSFETs are, the lower the resistance you can use.
Grey
