I got impression reading this forum that these Panasonic caps are good choice for this use. Just cant find what is the difference between these two models. Anyone have a clue, I have checked datasheets and could not spot any difference except tolerance.
And is there any other MKP cap worth trying with similar price/performance ratio.
Thanks for link.
Im also interested which brand and type of mkp caps are good for coupling bypass caps. I was looking at KEMET PHE426 but are there any better options?
From that link clearly the ECW-F(E) are the ones listing active filters in the intended uses (however they only seem to be available in 5% or 10% tolerance, which is not suitable for active filtering!)
Why choose one manufacturer and one series? Why not do a parametric search for the best match to your requirements?
the tolerance is indeed 5% or 10% , but because I used panasonic components before , I could say that 5% tolerance is more like 1-2%. And because these caps are very cheap you could buy a few more and match the value you need .
Ok I will get ECWFD, ECWFA and ECWFE they are cheap so its ok.
It doesnt need to be only Panasonic or ECW series that is why I said is there any other cap I should look at, but I dont want to use those expensive long axial "audio caps". Only place I know where to look is here Humble Homemade Hifi - Cap Test and this site.
And btw ECWFD also lists as active filter circuits as recommended application.
In this amplifier Tom is using a film capacitor for coupling LM3886 Done Right: Best DIY implementation of the LM3886 80W gainclone – Neurochrome ,
it looks like panasonic film cap.
- Design & Build
- Parts
- Panasonic ECWFD or ECWFA for signal path.
