For Sale pair of Dayton RSS390HF-4 15" aluminum closed-box subwoofers in Los Angeles only!!!
Things you have for sale.
Hello,
Bought these for a speaker project, but no longer need. Lots of low distortion, clean output. Made for a closed box of decent size, not ported. Could also work in IB/OB/dipole, though I didn't try that.
$147 each, or $273 for the pair. Prices are firm and fair. Local pickup in Los Angeles only!
Details:
https://www.parts-express.com/Dayto...-Series-HF-Subwoofer-4-Ohm-295-468?quantity=1
Features:
Extensively vented motor eliminates compression and allows quiet excursion
Lightweight black anodized aluminum cone for rigidity and lower moving mass
Triple shorting ring motor for ultra-low distortion
2-layer coil for reduced back EMF
Suitable for sealed or vented enclosures
Highest quality materials throughout for long-lasting performance
Specs:
Nominal Diameter 15"
Power Handling (RMS) 500 Watts
Power Handling (MAX) 1000 Watts
Impedance 4Ω
Frequency Response 18 to 800Hz
Sensitivity 91.2dB 2.83V/1m
Voice Coil Diameter 2.5"
Thiele-Small Parameters:
Resonant Frequency (Fs) 19.5Hz
DC Resistance (Re) 3Ω
Voice Coil Inductance (Le) 0.92mH
Mechanical Q (Qms) 3.02
Electromagnetic Q (Qes) 0.5
Total Q (Qts) 0.43
Compliance Equivalent Volume (Vas) 7.49ft³
Mechanical Compliance of Suspension (Cms) 0.22mm/N
BL Product (BL) 15T·m
Diaphragm Mass Inc. Airload (Mms) 306g
Maximum Linear Excursion (Xmax) 14mm
Surface Area of Cone (Sd) 829.6cm²
