i did some fixes in the soldering of my P3A and it stoped working!
i get 35 VDC on the output
when the speakers are dissconnected everything looks OK
and the green led lights ok
but when i connect the speaker a hummm noise comes from it
and the led lights lower .
when i dissconect the amp from the 220V
the supply caps discharge immidiatly
but when the speaker is not connected the caps discharge slowly....
(the speaker is OK!)
can you help me please?!?
I built a three channel P101 and after testing the boards and everything was working properly I installed it into the chassis. Somewhere along the way of installing everything a drop of solder fell between two of the diodes where I couldn't see it and created a short. That blew Q7 which caused me to have rail voltage at the output. I cleared the solder bridge and replaced Q7 and all was well.
Hope this helps.
Blessings, Terry
Hope this helps.
Blessings, Terry
i fixed the problem!
it took me a lot of time!
now everything is working but the output transistors are hot
(60 deg. C)!
even when im not listening to any music or something...
what can it be?
(its the same with those transistors on the second channel)
maybe the output trans are damaged...what do you think?
(but the amp is working...)
tnx!!
(60 deg. C)!
what can it be?
tnx!!
benmanf said:but, the bias trimpot is even not connected
and the heatsink is ok
at the begining it was'nt like that...the transistors were cold
Sounds like you have modified the P3A design. You can't ask questions without telling us what you have done. Why don't you post the schematic.
A bias trimpot is pretty important in most designs. So if you had it working somehow without it and you were happy then put the amp back to the way it was when it worked.
A P3A constructed as designed by Rod works perfectly. Your not using Rod's PCBs or following Rod's construction instructions are you?
Greg
- p3a not working, help!
