Hi tube experts.
I've picked up someone else's abandoned DIY project, to build a pair of mullard 5-20 monos. The circuit itself I'm fine with, I've built preamplifiers & phono stages before. But this is the first time I've had to deal with OPTs, so can anyone offer me some guidance?
What should I look out for when choosing one? Is "more-expensive-the-better" the rule here? Is size & weight the key, & can I get better results more cheaply just by oversizing? Can anyone recommend an OPT for this circuit?
Toroidals seem to have very high bandwidth but I'm keen to keep the project vintage-like unless there is a major advantage.
Also having looked at these things on the web for a day or two now I'm getting confused. Anode to anode load for t/x's supposedly designed for mullard 5-20 range from 3.5k to 6.6k. I would've expected it to be a constant. But I'm a newbie, so I know nothing
Thanks a lot
Ed
Thanks a lot
Ed
