Output Transformer +,-,?
Thank you all for your reply's. I e-mailed Jack at Electra-Print, and he e-mailed me back in a matter of minutes. I had it hooked up correctly, I think.
I have a green and a brown secondary wires. Jack says the brown should be grounded. That will extend high frequencies about 2K.
Does he mean that it goes to the negative speaker terminal? Or does he mean it goes to the negative speaker terminal and system ground (amp/chassis)?
Thank you all again.
