Output transformer for a 6EM7 headphone amp
I've decided to build my self a spud headamp. I'm thinking on the lines of Squeezebox --> spud --> AKG701.
I've got a few 6EM7 that should do the trick. The only SE transformers I have are 5k->8R scavenged from a reel to reel tape machine, I think the original amp had EL84 as output tubes.
I'm quite new the tube side of life, so can any one tell me if a 5k - 8T SE transformer will work ok ?
6EM7 --> 5k..8R --> 65R (AKG701)
If not I have in mind a multitap transformer, made by Oxford Electrical Products, part number N35A002F, RS part number 210-6475 (rswww.com), not sure if this link will work http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2106475
The windings with ratios can be found here:
http://img-europe.electrocomponents.com/images/L217567-01.gif
If I can avoid spending more money that would be ideal, otherwise, I believe I can go for the OEP transformer.
Comments much appreciated
FS
I'm based in the UK, most US items end up costing lots of money with S&H charges applied
With triodes, maximum output is achieved with a load impedance of 2-3 times the tube's plate resistance. Higher impedance will reduce output somewhat, with lower distortion - a good trade-off with headphones.
5K will work fine, and you can even deliver close to a watt to an 8 Ohm speaker if you want. Depending on the sensitivity of the headphones, you may want to attenuate the output with a series resistor or voltage divider. You should terminate the 8 Ohm output with 8-10 Ohms.
