output mosfet fails if + and - supply shorts
Hello!
I have a question, why the output mosfet IRF640N fails and amp goes to protect, if accidentally shorts the +- of the amp? The second time I short the +/- supply the output mosfets fails again, do it at 3rd time and another mosfet fails.
These are newly installed fets, Did I used a counterfeit mosfet? or the low voltage protection is not functional?
This is amp is china made amp, 850rms mono. It uses 2 NOR Gates.
regards,
Armand
