Hello all!
In some MOSFET amplifiers there is a zener btw source and gate of the output devices.
I suppose they are there to limit the maximum gate voltage and by doing this they limit the maximum current flow thru the output stage. (correct me if I'm wrong)
And if the value of the zener is choosen right a short circuit accross ground and output should not
damage the output stage.
My question is now:
How do I calculate the value of the zener?
I suppose:
If I know the maximum current thru one output mosfet, I
multiplie it with the number of output mosfets.
Now I look up this current in the transfer characteristics diagram(gate-source voltage vs. drain current).
I suppose the value of the gs-voltage at this positon minus 0.7V should be the value of the zener.
Am I right?
Patrick
My question is now:
I suppose:
Am I right?
Patrick
