Hi all,
I need some help on this amp i've created. Its a quasi comp push-pull classA that runs up to 50W with 2A of idle current. Nothing particulary innovative here, just box standard building blocks joined together. It should work fine, and on breadboard it does as long as it dosent drive into too much capacitance. The problem i have is on breadboard ( plugboard or whatever ) the amp runs fine, sounds astounding but a destructive oscillation can be triggered by stuffing around 470pF or more on the output. The oscillation is rail to rail and unstoppable once it is triggered. The .33R emmiter resistors then fuse saving the output devices ( thew! )
I have also built a prototype on veroboard hoping the lack of capacitance that the breadboard suffers from and lower resistance joints would help eliminate the dangerous oscillation. Upon testing the prototype i havent yet seen any destructive oscillation but it seems to have been replaced by a milder 2v Pk high freq oscillation that is present all the time.
I have tried everything i can think of to cure these problems but now i'm all outta ideas. The funney thing is these problems dont seem to show up on sims.... If they did i could maybe attack them using technology!!
Can anyone pls pls help me as my AudioFidelity A100 is annoying me with its noisey fan and i need a change!!!.. Never had these problems before... Waa!!!
I attach the circuit diagram and if anyone wants it i have the sim model for use with National semis Multisim. It's about 200K in size so email me if ya want it. The model shows different tranny's in the current mirror from what i'm actually using. The ones i'm actually using are 2SA970's
Cheers for reading... i'm going for a beer now..
