Hey Perry just trying to see how the middle secondaries connect to the output caps....I don't see any traces
It's a 3-layer board. The ground is in the center of the board. If you look at the source leg of the PS FETs, you'll see that they have no visible connection to ground.
It looks like someone has replaced a toroid before....so I removed one toriod. And didn't get continuity from one if the pads...it looks like someone drilled the pads out...bigger
So I'm going to reinstall toriod..and solder both middle legs of secondaries together.Thanks Perry...first time working in one of these.
I think you can can use a bright flashlight to see where there are open areas. From the photos I have, it appears that the top and bottom of the board are clear around those pads. If they're connected (they should be), no light should pass around the pads.
- General Interest
- Car Audio
- Orion Hcca 150r
