Orion 2250 SX capacitors
I wonder if these caps are normal for this amp, and if so what value they are? Believe it or not the way they are in there I can't get the values.
The two in the upper corners of the first pic.
Thank you.
Thank you Perry.
I don't have multiple boards.
If I removed them, I think I could read them at least. One of them is 50 V, I can see that much.
The casing on one looks damaged, but maybe I should leave them be.
I don't have the equipment to measure them.
I am going to check around some more, thanks again.
