Orion 2150sx
Is this amp worth trying to repair or is it a lost cause this is how i bought the amp guess i should have opend the bottom cover first..
Notice the inductor in front of the torriod its burnt and it needs all new power supply fets,outputs,regualtors,ect ect..
I have another 1 of theese amps with a bad inductor also..
I am going to replace the fets and outputs since they are shorted..
The amps is using SMP60N06's Wondering whats a good replacement for them??
Also Wondering does anyone know what core and guage wire i need to make new inductors for the power supply?? Or how do i go about ordering it as far as how do i determine what core and guage wire i need?
The core on 1 of the amps is not re-usuable all the coating is burnt off...
Any ideas on how to figure out what core i need to buy??
Also the wire on theese is 3 or 4 strands twisted together and then wrapped around the core do i need to only measure 1 strand then twist 3 or 4 of them together when rewinding it?
replaced all power supply fets , gate resistors, drivers in the power supply..
All of the outputs are removed right now...
Perry stated i could use the inductor in the amp for testing right now..
Amp draws excessive current when i hook the remote wire up..
Anyone have any ideas?
