Hello,
I understand that placing high-level low impedance signals next to low-level high impedance inputs can cause noise. But what are the general rules about component placement for minimizing noise?
The following is an example circuit which is supposed to be the input / output buffers of a parametric eq. Here the schematic:
and a corresponding layout:
Can someone explain how the components of this circuit might be moved to better reduce noise?
Thanks,
Mike
Thanks,
Mike
Placing outputs near inputs can create crosstalk or instability, not noise. Noise comes from the components themselves: thermal noise, shot noise, flicker noise.
I strongly recommend separating the signal ground from the power supply ground, that will minimize the possibility of inducing power supply noise in the signal lines. I do this in everything I build.
R2 and R4 are not needed.
The ultimate level of noise depends on the component values used and particularly the opamps. At low circuit impedances a bipolar device such as the LM4562 will be quieter... but it's all a matter of degree, and tbh noise (hiss) is often the least of the problems. As others have said, pay attention to grounding.
This circuit as it stands isn't suitable for swapping the FET opamp for bipolar.
Do you mean like the following?
But with a separate ground wire running back to the power supply ground?
Or are you suggesting that the signal ground actually have no connection to the power supply ground at all?
Also regarding signal ground, I was going to twist signal ground wire around all wires coming off the board (the red pads indicate wire locations). Is this practice of twisting a signal ground around wires recommended? Or is it only useful under certain conditions? What are those conditions?
Can no one follow through with a comment about this? I would really like to understand it.
Regarding separating signal and power supply ground, does that mean just having separate wires back to the regulator or actually not connecting the signal ground to power supply ground at all?
Mike
http://www.diyaudio.com/forums/diya...ng-interconnection.html?garpg=5#content_start
Run the signal ground to the star separately from the power supply ground, don't leave it floating.
Follow the recommendations in the linked article for all of your input and output connection grounds - a star of stars is probably a good idea. I use twisted pairs for internal signal connections, others suggest a small shielded cable for unbalanced signals. Not sure if there is an advantage or disadvantage to either.
Hi All,
I also do separate audio ground and supply ground, in the circuits i'm building on breadboard : Diff amps, bal out, etc.. but after reading "audio component grounding and interconnection" i don't know if it would be a good practice to run the audio ground wire from the middle of the audio ground bus instead of the end, in a sort of "star" point arrangement.
Thank you very much,
JAY X
JAY X
- Analog Line Level
- Organizing Components for Low Noise?
