I seem to be having trouble locating a OHP projector here locally (so I can rob the parts fresnel and projection lens out and take the "custom" route). Ordinarily, these things would be a dime and dozen around here, but since I'M actually NEEDING one there seem to be none to be found!
I've read in the forums about old slide projectors being used, but mostly by the fellows wanting to use very small LCDs. My question is, can optics from old slide projectors or old reel-to-reel 8MM movie projectors be used for projection of a 5" LCD? Is the "aperture" or focal length too small to correctly focus this style of lens setup? (I hope to use a MH bulb with reflector through a 5" LCD panel).
One further question, I had hoped to use the fresnel from the OHP and I've read in various places about the "page magnifiers" having to be used "back to back" to work correctly. Are the page magnifiers different in function or type than the fresnels found on OHP's?
Thank you in advance and sorry for all the questions!
