I'm using an Oppo 105D with the latest official firmware and I've had a skipping problem while streaming TIDAL for a while now. Not all songs give me a problem, actually only some, but the ones that give me a problem always skip in the same places and in the same way, as if I'm listening to vinyl with known skip places. It can be from 2 to 5 glitches on a song or just one. I emphasize that these are always the same tracks. When I try stimming with the PC Tidal desktop app on the same songs, I don't have that problem.
The sound is better when I stream directly from the Oppo, so I would like to fix the problem if possible.
I tried another rooter and it still glitches, although a little differently and a few seconds later or earlier than the usual places. I didn't take the device to someone else's system to try it on someone else's network...
These are the songs that give me trouble:
Streets of Philadelphia (Single Edit) Bruce Springsteen
The Robots (2009 Remaster) Kraftwerk
Atchafalaya - Live From Dordrecht, Het Energiehuis / 2014 Snarky PuppyMetropole Orkest
Bruce Springsteen, for example, always skips at 14 sec, 26 sec .... And I have the most glitches on that song. Also, it initially starts a little fast in the first few seconds and then picks up a good speed.
I will definitely take the player to someone else for a test, that it has nothing to do with my local internet network or some interference in the distribution of the cable operator in my building.
Oppo skips/glitches Flack HD and MQA, 16/44.1 too. Only mp3 does not skip. I use licensed Bubble UPnP for navigation with Oppo 105D as renderer.
I have no idea what could be causing this problem. Even though I'm not a regular user of Qobuz, visitors played songs from it and I didn't notice any streaming problems. Is there some miscommunication between Oppo streamer and Tidal server???
Thank you very much for the answers and ideas. I hope you try these three mentioned tracks on your Oppo 105D units and report your impressions.
