Has anyone here ever heard the Monacor DT-300 tweeter used along with it's waveguide? If so what are your opinions of this setup? It seems quite reasonably priced also.
I've heard that waveguides offer numerous advantages, and I thought that trying the DT-300 along with it's waveguide attachment would be a good way to go.
The plan is to replace the existing tweeters in my 2-way bookshelf speakers, it may be a little tricky as the waveguide is quite a bit larger but I'm sure I can get around this issue somehow.
I'm hoping to crossover at 1.8KHz with a 48db/oct LR filter as I'm using an active XO. Would this be too low as the official spec sheet says that you can crossover at 2KHz when using a 12db/octave slope.
