I am in a speaker building mood. Does anyone have opinions on Parts Express 701 Usher Kit? Any other suggestion sfor less money/better performance?
It seems like it'd be an OK monitor. More like "speaker assembly" tho.
I'm going to try to build something like magnetar's latest for a little less money. Having not heard either model, I can safely bet my net worth on which is a more satisfying sound.
magnetar's new OB
magnetar's new OB
for you info, I have bought the Usher 8945 driver and the higher model 9950 tweeter both are compatible and sounds quite good. However, overall efficiency is 87db.
There is one main drawback the efficient is low, after apply baffle step the efficiency drops even further to around 85db or less. I use active x-over so I don't lose on baffle step.
I you want to proceed with 701 kit I suggest you want to view this site:
http://www.geocities.com/woove99/Spkrbldg/Usher_701.htm
talk to the host he has good knowledge on Usher and approachable.
cheers.
cheers.
