labrynth
Here is what they sent me.:
items description Labyrinth Fronts Labyrinth Centre Labyrinth Rears
loudspeaker System "3 way,bass reflex" "2 way,bass reflex" "2 way,bass reflex"
Driver "4""x 1+1"" x 1+ 4 "" x 4" "1 "" x 1+ 4 "" x 2" "1""x 1+ 4 "" x 1"
Finishing varnish varnish varnish
Enclosure 15 mm MDF 15 mm MDF 15 mm MDF
Grill black fabric black fabric black fabric
Color white/silver/black white/silver/black white/silver/black
Dimension(WxHxDmm) 140x1130x240 450x140x180 284x225x150
N.G(kg) 15 5 3
Carton Dimension (WxHxDmm) 325x215x1220 210x535x500
G.W(kg) 17 13
driver(tweeter) cone materials silk silk silk
driver diameter(inch) "1""" "1""" "0.75"""
magnet diameter(mm) 70mm 60mm 70mm
magnet weight(g) 230 101g 150g
magnetic shielding no yes no
driver(midrange) cone materials paper
driver diameter(inch) "4"""
magnet diameter(mm) 80mm
magnet weight(g) 360g
basket iron
surround rubber
voice coil 25mm
driver(woofer) cone materials white paper white paper white paper
driver diameter(inch) "4""" "4""" "4"""
magnet diameter(mm) 80mm 60mm 70mm
magnet weight(g) 360g 101g x2 150g
basket iron iron iron
surround rubber rubber rubber
voice coil 25mm 25mm 25mm
parameter rated impedance(Ohm) 8 8 8
power handling(W) 80 40 30
maximum power 120 60 45
frequency response(Hz) 50-20KHz 50-20KHz 60-20KHz
sensitivity(dB) 89 87 87
crosover frequency(Hz) 1000Hz/3500Hz 4000Hz 4000Hz
This is there top selling speaker
