Hi all, I'm designing a preamp. I'm relatively new at this. I have distortion section of the amp that has channel switching, then it goes to 2 tonestacks. This is more or less and opinion question. Which way should I wire it.
1) Clean channel A goes through Fender tonestack (with level control), Distorted channel B goes through Marshall tonestack (with level control)
In other words your playing with distortion with marshall and when you flip to clean, the tonestack also changes to fender
or
2) first choose which tonestack you want with a toggle switch (choose either fender or marshall) then the stomp box only changes from clean to dirty, but the tonestack stays the same.
out of these two designs, which do you think would be better? Don't worry about the gain differences, I'll make appropriate adjustments.
or 3) leave some other ideas!
Thanks all!
or
Thanks all!
