First of all, many thanks for the time that you spend all of you to reply in a so difficult subject such as the OLG.
You can see that, from yestarday untill now i have only a few replies. Instead for subjects such as output relays and buzzing transformers there is a pactolus of replies in few hours!
From my experience all the methods you propose seems like effective and not dangerous probably to burn any active or passive element of the amplifier because they ensure a stability during the measurement process.
Usually, in my amp. projects i preffer an input sensitivity of 0dBV, or 1Vrms input for full output swing. Also i am busy only with supply levels from +/-60V to +/-86V. Thus as you can understand i am working with a Closed Loop Gain from 38,5dB up to 41,7dB accordingly. Also, because the topologies that i use are of those which guarantee the stability in spite of they offers a supposed superb sound quality, never i have seen phase shift or oscillation of output (yet with the connection of a reactive load the ringing it is small due to 8ìH inductor from 2mm wire which i use in the output) at least up to 100KHz. Above this frequency limit, all the signals are blocked due to the input filtering, the whole feedback loop and the nested feedback loops incorporated.
In reality, i have not any problem in my projects but i am very curious to see which will be the behaviour of one of my amplifiers without the support of all the previous reffered feedback aids.
I like the method proposed by John, because i have an appropriate function generator of 10MHz (Hameg HM8130) which also incorporates a rich menu of settings including also its own output signal voltmeter (i checked this with my DSO, the value indicated it is true) thus there is no need to connect any other instrument in the disconnected feedback node which can cause instability due to its interference with the output of generator.
After i will try the method proposed by Hans which seems likewise good as the John method.
Finally, i will make a comparison between the results of the two methods and i will refer in a post the conclusions.
Thanks a lot for the advices, to all
Fotios
