Sorry to bug everyone, I've gotten
bit by the speaker/amplifier virus.
Right now I'm working on my ambitious
speaker project but also am compiling
data on amplifiers.
Amplifiers confuse me because
there is two audio factions that seem
to have two opposite views.
The issue is.. Is simple circuit design
sonically better? Does the use
of op-amps (chips, ie, 5534, etc.) in
the signal path contaminate the
music ?
Exotic car audio amplifier manufacturers use op-amps (chips)
in the signal path and they use them for electronics crossovers and use
them for tone controls... and they
use capacitors in the signal path.
Nobody claims sonic inferiority
by doing this.
Exotic home audio amplfier
manufacturers use no op-amps,
no capacitors, nothing in the signal
path - hehe /joke-->If they could get away away with it, they would use a
piece of wire to amplify music if they
could get it to work.
This faction claims everything is
bad in the signal path.
How can both factions be correct ?
I can understand the need for simple
circuits, it's fun to find a simple solution to a complex problem.
Example, if you were asked to build
a vehicle for 2 person transportation,
the car audio faction would design
a Corvette, 4 wheels, seats 2, goes
fast, reasonble price. The home audio
faction would build a moped because
'simple is better", it's lightweight,
only has 2 wheels... but they would
charge 2x more than the Corvette
right ?
data on amplifiers.
music ?
by doing this.
right ?
Build it, and find out
The car audio example is really bad, because car audio is targetted toward audible music in a very noisy environment with an unreliable electrical utility and a distracted audience. Totally different from dedicated listening in a quiet home with conditioned power and acoustic room treatment.
That aside, I think you should use opamps if they fit in with your philosophy of design. They are terribly convenient for electronic crossovers, equalization, current-to-voltage conversion, and voltage gain. Some of these circuits can be easily build with discreets instead of opamps. For example, you can build an I/V converter or a 3rd-order low-pass filter out of discreets with no problem.
I avoid opamps in most things. I once used one as the voltage gain stage in a headphone amplifier, and was happy with the result. But I don't use them because I don't need them. The audio band extends from DC to perhaps 96kHz. I do not need an opamp capable of swinging 135V/µs. I believe that if you do use an opamp capable of driving a 1GHz signal, you might accidentally wind up with a lot of 1GHz noise on your otherwise clean audio signals. And that would be Bad.
--The car audio example is really bad, --because car audio is targetted toward --audible music in a very noisy --environment with an unreliable --electrical utility and a distracted --audience. Totally different from --dedicated listening in a quiet home --with conditioned power and acoustic --room treatment.
I spent
10 years of doing car audio, mostly
for myself and helping others,
taking amplifiers apart to see
what makes them tick, but never
reaching the stage where I could
design from scratch, the only
thing that I was able to design
was text-box active filters using some
books as guidance and it worked
well.
I'm not one of those "bumping" dudes when it comes to car audio, I always built using the "tweeter down"
approach to seek quality sound
not just "boom" "boom"
After doing the car audio think, I could
never find any happiness when
visiting the local high end audio store
auditioning expensive speakers and amplifiers, my car audio experiences
provided more audible pleasure, perhaps because it was more challening
to work inside a car using multiple
drivers in a 4 way full active speaker systems. The quailty was sweet.
Even today, I can't seem to find
home audio happiness when it
comes to speakers, not so much
amplifiers, but the good amps I like
cost way tooo much.......
The audio adiction leads to the
desire to DIY speakers and
even amplifiers if a good design
is found - hehe
I'm breaking some speaker design
rules for my "1/2" line array project,
seeking more "horsepower" and
sacrificing some ride comfort - hehe
I'm wondering if the same could
be done for my amp project - hehe
Insert op-amp here, etc...
I spent
well.
is found - hehe
Hi Guys,
The purist reason why op-amps are bad is to do with negative feedback - which is also deemed bad when it operates from the output of a high-gain system back to its input.
Any negative feedback needs to be very carefully controlled with respect to phase, group delays, and (voltage/current) clipping during transients.
The higher the feedback, the more control needed. Ideally, any such feedback should be local to each stage of the amp, to minimise the above effects.
Op-amps operate with enormous gain, and enormous feedback. They offer very little ability to callibrate the feedback to the characteristics of the amp and the signal being used, beyond a trimmer cap.
That said, on simple signals, they do a mighty fine job. On transients, and very "dynamic" signals, they are regarded with suspicion...
All said, though, if they sound good, then use them.
Bill.
Bill.
Just don't forget that with the great majority of recorded material the signal has already passed through many, many opamps. A couple more isn't going to hurt.
If anyone want's a signal that isn't opamp <i>contaminated</i> they are pretty much out of luck.
On the other hand, there are some recordings that are opamp free. What's a purist to do? Personally, I don't worry about it.
jwb said:Build it, and find out
Yep, they're certainly good for all those uses.
Can you justify this comment (about 96kHz)? I seek only clarification
I think Peter Baxandall did some experiments many years ago in which the maximum slew rate coming off a record (he deliberately chose records with lots of high frequencies such as cymbals, high hats etc) was about 2 volts per microsecond at the output of a 50 watt amplifier. I haven't seen such experiments done with CDs or other media but don't really expect anything different. Me? I still use 5534s. Wonderful little beasts. If I want low noise I use OP37s or LTA1036s.
As to high feedback, what's wrong with it? I've looked at some of these so called non feedback amplifiers and even built the odd wondrous one of them. All amplifiers have some form of feedback, even if it's local. Some of the so called magic stuff is marginally stable at best with ringing on certain frequencies (frequency dependent ringing... arrgh) and poor behaviour into real world loads. (I have to say that some equipment with overall feedback does the same). So, how does a competently designed and built amp sound different in its overall feedback and non overall feedback guises? Anecdote is no evidence BTW.
regards, Keith. (tilting at windmills again)
I think the answer depends on which specific opamp you are comparing to which specific discrete design.
Generally speaking, a properly designed discrete circuit specifically for an audio application will outperform a generic multi-application opamp. However, opamps are designed by some of the best engineers in the electronics world. They are wonderful devices.
The math for an opamp and some resistors is much more intuative and easier to apply than the math for a handful of transistors, diodes and resistors.
To get a start on discrete opamps:
http://www.passdiy.com/legacy.htm
Download D.I.Y. Op Amps
http://www.borbelyaudio.com/index15.htm
Download JFETS: New Frontiers Part I & II
To get a handle on opamps, look up the application notes for the opamp of your choice, or try some of the opamp cookbooks.
If you have access to a computer, there are several demo SPICE programs.
http://beigebag.com/
http://www.linear.com/software/
Car electronics are used in a unique enviroment and designs are very much driven by price points, both list and dealer cost.
Aud_Mot
Aud_Mot
Sure. Biggest, baddest digital audio is published with 192kHz sample rate. The maximum frequency in that system is 96kHz. Most analog formats are way, way below that. Certainly vinyl and cassette tape.
For shorthand I usually figure the audio band is 0-100kHz.
Opamps are like everything else electronic; they're cheap, expensive, good, very good, plain ugly, etc. I tend to use discrete components on my designs because i like being able to tell EXACTLY what's going on there. But sometimes you just can't beat a good opamp, either for flexibility or specs. Ever checked the datasheets on the best Burr-Brown stuff? (drool)
Some very well respected hifi companies regularly use opamps in their kit.
AFAIK, Musical Fidelity uses them in the phono stage of their newest A3 amp, the Michell phono stages use them too as do the Sonneteer Sedley DacT and Lehman phono stages. The MF, and Lehman are regarded as good stages while the Sonneteer and Michell are considered very good by most folks.
At the end of the day, implementation will have a lot to do with the resulting sound. How well are the power supplies sorted, what standard of passive components are used etc and so forth.
I mean, in theory most of these opamps are supposed to have huge levels of PSRR. If that's the case, then why does improvement of PSU (esp in the case of the michell and DacT) and going dual mono have so much impact on the sound?
I'm in the process of further developing an MC RIAA stage I built to incorporate higher grade opamps, caps and resistors but even with the bog standard cheap metalfilms, MKT polyesters and NE5534 (common audiophile response... Blleeeeccchhh!) I'm getting quite good results.
Sure, 2 or 3 valves would be more elegant but it'd weigh and cost lots more, require higher voltages and definitely couldn't be run on 9v cells or 12 volt cells.
I would say, if properly utilised not evil.
Drew
Drew
Like everything they have their places. In my opinion the best discrete design will better the best opamp circuit. while a cheap opamp circuit will best a poorly done discrete circuit.
As for the datasheets on BB's opamps, sure they look great on paper, but so do discrete transistors compared to tubes, and yet many people still argue the sonic superiority of a vaccuum tube (I won't impose my views here).
"Evil" silicon
Truth be told, there's good circuit design and bad circuit design.
A good design engineer can build a superb audio amplifier using operational amplifiers that are considered "plain vanilla" today, while a hack can make a mess even when using the best of parts. In this way design is a little like sex, the secret is in the execution!
I may be getting close to a nerve now, but a lot depends on what criteria one uses to define "superb". Are we referring to objective, quantifiable performance or vagaries like "musicality"?
Joe
Joe
Re: Keithj: LTA1036?
Whoops. Faulty memory. Upgrade necessary. LT1028 it is.
regards
mirlo said:If I want low noise I use OP37s or LTA1036s
What is a LTA1036?
LT1036 is a voltage regulator. Did you mean LT1028?
Just wondering.
regards
OP amps
Hello,
An amp that uses global feedback is working much the same way as an OP amp. It's just abel to deliver more power to the load.
Op amps are designed to have infinite gain at DC, but just as you design a pole in a power amp the same is done in a OP amp.
The µA 741 (old model) had two versions, one with no pole, and one with a pole at about 5 Hz.
Newer OP amp may have 100 dB gain up to 100 - 1000 hz, but after this pole freq, the gain falls by 20 dB/ decade.
This results in gain about:
80 dB at 1 kHz
60 dB at 10 kHz
40 dB at 100 kHz
The problem is then that there is less "muscle" to repair any error.
I made a 6. order band stop filter at 1 Khz BW = 50Hz using opamps.
I tried two different opamps:
LM4558 and LM833.
The cheaper LM4558 performed far better than the LM833 which has more OL gain at 1 Khz than 4558. This leads me to the conclusion that the best way to find the right OP amp for the job is to try out different types, and see how they work.
There is plenty of data on the datasheets, but only one way to see if it works well for you.
Build It !!
\Jens
Hello,
80 dB at 1 kHz
60 dB at 10 kHz
40 dB at 100 kHz
LM4558 and LM833.
Build It !!
\Jens
thylantyr said:Sorry to bug everyone, I've gotten
data on amplifiers.
music ?
by doing this.
right ?
All you need to know is Miller. Miller capacitance is why op-amps are not used in high end amps. Many transistors = lots of Miller. Miller capacitance affects slew rate. If it were all as easy as an OP-Amp, cows would fly.
Use descrete componants and as few as possible in the signal path.
I theoretically used to agree about good design and layout being important (joeblutz) but now I agree from practice.
I bought a Lehman Black Cube some 12 years ago and fed up with hum and other problems from a valve phono stage decided to see what I could acheive with the Lehman.
I have removed all the Jamicon and Wima caps in both the Shuko/PSU and the phono stage itself - using Philips LL PH & BG/FKs in the PSU - what a difference, especially the Philips.
Bg/FKs/NX/Silmics & ERSE (what a surprise) in the phono stage - it is now seriously good.
The question is, will changing the op-amps - 1 x OP275 & 2 x SSM2017 bring further improvement.
DrewP - I now will only use MC type cartridges in future, I'm presently using a Pickering low o/put hybrid, I'm finished with MM.
There are many partisan and polarized opinions about replacement for the OP275 - THS4032, AD8599/8620/712, LM4562, OPA 627/2132 and for the SSM2017 - INA217. I would appreciate any experienced (please no theorists) comments even including - leave well alone.
Thanks in advance for any advice.
Black Stuart said:(please no theorists)
Then why did you revive a 6 year old thread that was mostly a theoretical debate?
Same as everything else in audio opamps are coloured. If you happen to like their sonic signature - great. As Cunningham's post above says "cows would fly". I use them as sparingly as possible, as adittedly it's neither easy, nor cheap to completely avoid them. And yes, they've come a long way since the 5534.
As for the OP275, it is particularly coloured IMO. A darkish, pleasant, old tube school type of sound. Quite nice, but not very dynamic or detailed. IMO the AD8620 will run circles around it but may not have the same solid bass. I hate modding commercial equipment anyway. It's often easier to achieve good results by building from scratch, even if it involves cloning something you like. Too many compromises in midfi stuff like Lehman - not enough PS, not sufficient room for nice parts. Rather sell and DIY
- Op Amp chips in the signal path - evil or not evil ?
