Hi people, any idea for plans to build Onken for Fostex FE166En? I've heard them sound and look great!
Thanks all,
Z.
Thanks all,
Z.
Hey Dave: remember I had pretty good results with a FE166e in my K-line (hybrid Karlson) so that is a possible option that is smaller than a horn. All the best Moray James..
Yes i remember that one -- i knew it was the subject as soon as i saw your name 🙂 ... (someone said an HD crash ate your copy of the plans?). I also seem to recall you saying it did a bit better with FE167?
dave
dave
I've already built a horn for 166, Fostex' original, but after having heard Onken's one... well I'd like to try! As seen in few uncomplete picture on the net Onken seems similar to Solo-166 project. Isn't it? Anyway, has anybody Onkens plans?
You need FE167e (One Sixty Seven) for Onken style enclosure.
Why? Driven with a high output impedance or adding some series resistance allows a F3 = Fs Onken without exceeding the vent length limit and you still have whatever 'sweetness' this driver may have over another.
GM
Hey GM.
Not such a bad idea if efficiency isn't an issue. I added 6 ohms of series R, but system eff. is down a little over 4dB. I also used n=5.7, just to make things easier.
jeff
jeff
Was looking for a few other options for my FE166ens besides the BIBs in which they are in. Googling brought me to this thread.
Did anybody end up building a Fonken with the FE166en?
Any feedback suggestions will be appreciated.
Thx, Zia
Thx, Zia
I just simmed one. F3 ~110Hz, F10 ~86 Hz.
Might as well put it into a butterworth 5.3 litre sealed box and XO to a woofer (150 Hz XO (3rd order acoustic)).
dave
Use a valve amp of sufficiently high output impedance (or add series resistance to one of lower output impedance), and you should be able to get more extension than that.
While it might seem a crude measure, re-using cabinets for the FE**7 series with a FE**6 driver and a resistor seems like something to try.
Alternatively, Variable Amplifier Impedance - that'd keep the driver sensitivity otherwise lost by the resistor.
Chris
Chris
hopefully 166EN will like this K6.5 (middle enclosure) - JL has it loaded with 167 and is awaiting 166 - the 8" enclosure to the left is supposed to sound very good with FE206EN and will keep up with the big K (and beat it for coherence and vocals, etc) IIRC external bulk for the 6.5" K-coupler is ~1.7 cubic feet
GregB. designed the "SK6.5"
the little coupler in the middle with 167 might do F10 at 50-55Hz with 166EN - my buddy is going to tweak its vent first - that's a FE206EN in the left Karlson type-coupler
Green = Z with 167, Blue = 166
- Full Range
- Onken for Fostex FE166En
