I'm building on a power amp.
It will use a CFP, and I'm thnking on omitting the usual "emitter" resistors (0.1 ohm) (here it's actially collector resistors.
Thay are quite bulky, will generate distortion.
Guess they will help stabilise bais curent (and make it easier to ajust ... measure voltage drop over these resistors)
They will also limit the current somewhat and might also act as fuses in a fault situaion.
Any thoughts?
Anyone tried this?
Any comments to sound or measurements?
Seems that the AKSA amps do not use these!
Kind regards Baldin
PS. A Merry Christmas to all
Any thoughts?
Anyone tried this?
Kind regards Baldin
