Old FANE driver
Hey guys,
I've visited an old Hifi buddy and listened to his new open baffle project with old Fane drivers. I liked the sound and would like to copy that project but the driver seems to be a phantom. I've searched the "whole internet" and couldn't find any information on this driver.. let alone a sales offer.
It's a 12" driver and I think it must be from the 70s (the man. date says something different but I think this is just the serial number)
Here are some pics:
I don't have a pic from the front but it has a whizzer cone.
Does anybody know anything about this driver? Especially where it was mounted? Guitar amps? Organs?
I really would love to rebuild the project so any help is highly appreciated!
Greetings
Tim
This, the Fane 121/15 is a speaker that was used in some Vox guitar cabs, the ones with the seperate head (don't remember the model). It's a guitar speaker from the late 60's or early 70's i thought. It had two drivers in one cab linked in series (2x4oh). The amp i fixed with those was a couple of EL84 in PP config of about 20w in a seperate head. I don't know if that cab was original altough.
Reactions: IrieTim
Thanks for the hint. It's kind of difficult to find the right one tough because there are so many different iterations. The AC15 and AC30 we're sold with Fane drivers at some time but these had 122/10 or (lauter) 122/17. The ones with the separate amps were called 'Super Twin' as I understood. I didn't find any VOX pics with the 121/15 mounted yet..
There are many variation of the Vox amps, the speaker cab looked like the AC50 MKII (big box) cab that hat rebranded fane drivers. I personally think the AC50 MKII drivers were blown by one of the previous owners and he bought the closest to the originals, the Fane 121/15 nad put it it in.
The head was certainly modified, and looked more like a JMI Vox UL710 head, not like the AC50 head. I'm not a guitar amp specialist, but i did repair/maintain some of my musician friends amps when i was still living in the city. Now i live way to far off in the countryside for them...
Reactions: IrieTim
My very first speaker enclosures, circa 1967, contained Fane 122/10 drivers:
The salient point is that the 122/10s came in two versions, one with resonance frequency 40 Hz for hi-fi use, and the other 80 Hz for guitar use.
Reactions: IrieTim
I had the 40 Hz version which had a corrugated paper surround.
I'm afraid I didn't see the 80 Hz version, but would imagine it had a stiffer surround and/or spider.
However, it's likely the two versions were indistinguishable by sight. It would be a matter of reading what was marked on the box!
EDIT: You can see the guitar version here: https://reverb.com/item/34051607-vi...tar-speaker-driver-from-1971-pulsonic-cone-12
Checking out a 1960s Fane catalogue, I see there was a twin cone version called the 122/10a with an aluminium voice coil instead of copper, and 40 Hz resonance.
Does a higher flux density/bigger magnet equate to a higher quality speaker? 😵
A high flux density magnet gives a tighter, more controlled motion of the speaker cone.
In technical terms this corresponds to a low value of Qts (total quality factor).
For an open baffle we actually require a driver with a high Qts (> 0.77) which would correspond to a low flux density magnet.
The driver should also have a high frequency of resonance (40 - 60 Hz).
Reactions: IrieTim
Qts is the driver's resonance magnification at its free air resonance frequency fs. I think this may be where the "s" in Qts comes from.
I regard Qts as the "total Q" of a "driver" to distinguish it from the Q that is the resonance magnification of a loudspeaker "system" or box.
But hey, I'm no expert on the nomenclature of T/S parameters!
