sorry for this off topic question, but i dunno where to ask (lemme know if u know better forums)
i'm making a funtion generator (which will be used also to test audio equipment, so mebbe still on topic
. It is based on the MAX038 IC. The design is almost ready, but i have some problems with the output stage.
a proposal of the output stage to accompany this text is at http://mcbain.studentenweb.org/schema.jpg
The MAX delivers 0...2Vpp (sine, square triangle). This is the in input.
I want 2 outputs
1) a high voltage ac with dc offset
2) a low voltage "pure" ac output
for (1) i feed te innput signal thru a pot (to change amplitide ) in an opamp summer. The other source for the summer is a dc voltage. Dc is not amplified, ac is 12 times amplified. So i should arrive at a voltage of 0 ... 24 Vpp adjustable by the amplitude pot added with an independant adjustable (?) dc offset of -15 ... +15. This signal is fed thrue a unity gain buffer with large output current (to be able to drive 50 ohm bnc cables)
for (2) i just need the input signal, feeded thru an unity gain buffer. I guess 2Vpp is enough for audio testing (or isn't it ? )
i have problems combining the 2 circuits. The DC offset cant arrive at the MAX output pin (i thing the IC wont like that) and the dc offset cant arrive either at the the low ac output, so i added an extra 2 buffers.
i really dont know if this will work or if there are other methods (i dont want to use a switch, and a C to block DC wont pass the 1 Hz ... 20 Mhz range). I'd like your opinion. And please dont noobize me here, i just wanna learn something.
another last thing, is 2Vpp enoug for audio testin ? otherwise i would add an extra opamp to amplify the signal (to example 4 V pp). If i do so, can i replace the opamp buffer with a non inverting amplifyer or do i put the extra amplifier behind the buffer ?
best regards,
McBain
I want 2 outputs
best regards,
McBain
neat ic
neat ic indead
and no, at 20 Mhz the square isnt very square anymore
but take a look at the commercial function generators, the cost a couple of $100's and only get to a couple of Mhz's (seems the MAX038 does very good up to 10 Mhz and above)
if you guys are interrested, i'll set up a webpage about it, with pcb's, when the project is finished
the gen will feature
* waveform: tri, square, sine
* freq 1 Hz ... 20 Mhz
- range (3 decades for the moment)
- course
- fine
* duty cycle adjustment (with this it is possible to get a more pure sine waveform) with defeat switch
* output 1: 0...24vpp adjustable+ -12...12 adjustable dc offset
* output 2: 0...2 vpp adjustable only ac
* ttl output
this on a board of about 10 * 8 cm (4 * 3.5 inch)
cost: $20 for the max, a quad opamp IC, a couple of high speed opamps, 2 unity gain buffers, some pots, switches and R's and C's
so nowhere near the cost of the commercial (mostly less good) function generators
best regards,
Ares Lagae
neat ic indead
- course
- fine
* ttl output
best regards,
Ares Lagae
will this solve the problem:
http://mcbain.studentenweb.org/schema2.jpg
or do i need to add an extre buffer between the connection to the buffer for the low ac output and before the differential opamp ?
waveform gen
Well, that depends on the value of the amplitude pot wrt the input resistor of the diffamp. Because of the input resistance, the ampl pot may not be perfectly linear. On the other hand, if you plan to use output level metering that is of no importance. On the gripping hand, if you have an opamp buffer to spare put one after the ampl pot.
My Heathkit waveform generator has a switch on the ampl pot with which you can defeat the offsett (just groung the DC input to the diff amp). I found that very usefull. There is only one output so you don't have to switch cables all the time, you can leave the DC pot as it is and quickly test with or without offset. It also makes the circuit a bit more simple. I strongly recommend you do something similar.
Jan Didden
"Things should be made as simple as possible, but not simpler"
ALbert Einstein
McBain said:will this solve the problem:
Jan Didden
ALbert Einstein
Mr. McBain,
Don't worry about the DC offset voltage appearing at the input of your circuit. As long as the OPA30 summer does not saturate it will keep its inverting input at essentially zero volts regardless of the offset voltage you select. Remember the inverter operates by maintaining a virtual ground at its inverting input.
For the same reason, no DC will appear at your second "pure" output. the OPA30 buffers aren't needed.
LOL
Joe
LOL
Joe
- Analogue Source
- [off topic] opamp question
