The only way to find out is testing the transformer: increase the output load step by step and monitor the output voltage and transformer temperature. Output voltage should not drop more than 10..20% and temperature should not exceed 60 degC
What was the power output of the amplifier from which this transformer was taken?
That should provide an estimate of the transformer's rating.
Frank Berry said:What was the power output of the amplifier from which this transformer was taken?
IIRC it was 2x25W but delivered by a single STK4042 (or similat) mounted on a miserable heatsink...
Btw this trafo isn't so small, weights about 2kg
- Design & Build
- Parts
- Of what value is this trafo?
