I am currently building a pair of Seas Thor TL speakers:
http://www.diyaudio.com/forums/showthread.php?s=&postid=58177
Seas also makes a Odin MK3 kit:
http://www.seas.no/odin_mk3.htm
It uses the same drivers and crossover as Thor, but in a bass-reflex configuration.
Would this work as a center channel speaker laying horizontal? I know that the MTM D'Appolito configuration is meant to be vertical, but I don't have room for a vertical center channel.
I am considering making one of these for a center, and two more of these later on for rears.
Would this work for a center?
Brian
Brian
If this would not work good for a center channel, can anyone recommend any other good speaker projects for a center channel?
Brian
Brian
Brian,
Many people don't like MTM sideways as a center channel. A vertical MTM with really close spacing may work. Do you have the vertical space?
Dale
Dale
Don't think an MTM sideway will make a good center channel. You're better off without one or one MT. Go with the Charis or Trym kit.
JMHO, of course.
BTW, I sold my center channel long ago. The dialogue projects from the TV, not above or below.
JMHO, of course.
I have vertical space, but I worry that the speaker position will be too high above the television if the Odin MK3 is used in normal vertical position.
Hi Brian,
How about a pair of MT's (one on either side of the TV) wired in parallel. This would put the sound source inside the TV. You could even make a pair of MTM's using something like the 4" Tangbangs.
Just a thought,
Rodd Yamas***a
Just a thought,
Rodd Yamas***a
TMT configuration
Hi, this is my first post, but I.m sure there will be more.
What about using the same drivers as Thor, but only one Mid/Bass with a tweeter on either side? This setup should have the same timbre as the Thors and avoid the problem of turning the Odin on its side.
Please, nobody assume I really know anything. My purpose here is to learn.
Didn't see it in the thread so I thought I would jump in 🙂
Speakers arranged in a vertical array disperse sound in a horizontal plane - or said another way they disperse in a plane perpendicular to the line created by the speaker array.
When I had space I put the mtm vertically over the screen (scanspeak solist from madisound) on a shelf and built a slight wedge tilting it directly toward the center of the room slightly down and squarely at the center of the audience - worked great.
I don't have the space on top now ( due to changing to a larger projection screen) and the mtm doesn't work quite as well from the bottom - Flawless from the top but from lower than ear level - it's ok but we're not really used to tweeters from below ear level.
Sooo. I'm thinking about building a small center with only one of the same midrange and tweeter.
No answers here - but hopefully thoughts that bring us closer to solutions.
Later
Ken L
Later
Ken L
1. if you are using a regualr TV does not the center channel have to be shielded?
2. MTM for stereo might have to be vertical. in the center channel dispersion charateristics might prefer a narrow horzontal pattern (of a MTM places sideways) and wide vertical pattern.
I am thinking of a 2.5 way with the follow config.
1. centre tweeter
2. 2 4.5" woofer in series one on either side of teh tweeter but the baffle is 165 deg instead of 180deg. I call these the middle woofers.
3. 2 additional 4.5" woofers in series (for difraction compensation) on either side of teh earlier 2 woofers again with the baffle at a further angle (150 deg wrt to the tweeter and 165 deg. wrt to the middle woofers)
4. grill will be a sort of semi circle to cover the wide curve of the system.
The width of the speaker will be about 30", height 6" or so.
what do you guys think.
1. centre tweeter
After looking over the comments, I am thinking of just building a MT and sticking it on top of the television. (There is a shielded version of the woofers)
Seas has a Claris kit with a 17mm driver and passive radiator:
http://www.seas.no/charis.htm
and a Trym kit with a 22mm driver
http://www.seas.no/trym.htm
Thor uses two 18mm drivers and the same tweeter as both of the above.
Would one of these match Thor for use as a center channel?
If not, could I just use two shielded odin speakers on both sides of the television? Would that suffice as a center channel? (Odin has the same crossover as THor)
Brian
Brian
you answred your own question. 🙂
2 odin on either side will work well. i use a similar method. only mine are 6" 2 way using Vifa TC series drivers. I toe them a bit in though. you can expriment.
Unshielded front speakers
How close can unshielded speakers be placed to a RPTV CRT?
They are a large floorstanding speaker.
Thanks,
Dale
Thanks,
Dale
i use a regualr 29" TV and mine are less than 1" away
however my friend owns a RP TV and he uses Dynaudio all around(Dynaudio 52 series). Dynaudio does not have shielded drivers although they are partly sheilded as the coil is outside the magnet and their magnets are a bit small.
he has no trouble with the MTM center on top of teh RPTV and the 52s less than 6" away on either side. The TV is 62". The room is 78" wide. He has his HT in his dining room. Reason? no wife! 🙂
- Odin mk3 for center channel?
