odd headphone question
I have a kind of strange headphone modification question, this is the only audio forum i frequent and i trust you peoples. so here goes, I got a metal detector for xmas... i like it so much (the hobby that is) that i am getting a better one for my birthday. I use headphones and my question is..... is there a very simple circuit i can build to attenuate the loud responses while keeping the quiet ones audible? by that i mean, when my tector gets a strong hit, i don't want to blow my eardrum out, but i want to be able to hear the quiet threshold at a reasonable level. basically I just want every thing over a certain audio level attenuated just enough, maybe even make it adjustable. i have headphones just waiting to be modded 😀 thanks for your help guys.
mike from santa rosa
given that you are not listening to music, a simple diode limiting
circuit will probably do the job, and can be placed in-line with
the headphones.
simply add a series resistor the impedance of your phones and
then two diodes in opposite directions in parallel with the phones.
For a higher threshold use two pairs in series. a small resistor
can be added in series with the diodes for less harsh clipping.
Instead of the level changing drastically, the sound of
the tone will distort more depending on the output level.
Alternatively a chip specfically made for DX'ing in amateur radio
is your best bet. (Large input range, low output range)
🙂 sreten.
