I just found a PCB sell in Ebay "Octal Akido HP amp"
If I use it as both HP amp and preamp. How is about the sound?
Anyone has ever use this HP amp as preamp? Please comment
DIY PCB Board OTL Tube Headphone Amp Aikido White Cathode Follower 6SN7 6BX7 | eBay
Or Cary AE-1 as preamp by modified under Mr. Koonw's advices is better?
http://www.diyaudio.com/forums/tube...-6sn7-e88cc-hp-amp-90vdc-plate-capable-6.html
Be aware that the ebay board is not from Broskie the real Aikido guy. My experience is the Aikidos configured as an HPA don't necessarily play well with low Z 'phones. It very much depends on the phones. Some OTL HPAs use negative feed back to drive lower impedances, Broskies do not. Neg feedback might dilute the Aikido "goodness" An Hpa configured one might be OK as a line stage but won't be optimal.
Cheers, steve
Cheers, steve
Of course John B. uses gNFB for even 300 ohms load, see Aikido Headphone Amplifier. For 32 ohms that isn't possible with just gNFB and Aikido cathode follower, so have to use White cathode follower with gNFB. This is technically speaking, sonic wise don't know. I image you can sim and look at the harmonics distortion content for clues or is there already one you can look?
I got the sch for 8 ohms load with a pair of 6c19p but in SEPP mode, the harmonic is comparable to the full blown 25W amp. The above has no way to drive 8 or 16 ohms load anyway.
Printed Circuit Boards and Kits
Why not get the real deal from the guy himself. This was the first tube project I undertook and the documentation was superb.
