I just got the panel in not to long ago and ready to hook it up. My question is, is that there are two lead ins; a digital (9 pin) and an Analog (15 pin two row). I'm pretty sure I'm looking for the cable that goes into the Analog but I have not seen a 15 pin two row in a good while. Could someone recommend me how to hook this thing up to a standard 15 pin three row that way i can go from my pc to the panel?
This is the panel I'm talking about :
http://img.photobucket.com/albums/v419/blu.../Picture002.jpg
and here is a pic of the connections :
http://img.photobucket.com/albums/v419/blu.../Picture001.jpg
You don't mention what nView panel you have. If it's a nView Spectra C then post 7 of this thread shows the pinout info.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=4845
oh sorry about that. It says on the case that it is a ViewFrame Spectra Plus. The two leads are both male. Think I forgot to mention that as well.
The nView Spectra C and Spectra Plus use the same cable. You can try and find a used one on ebay or make your own using the pinout info.
After doing some further reading from the post (thanks again) I came across this item : http://tinyurl.com/zcmtz
Just curious if this would work instead of having to make my own since I'm not too good at soldering.
You can also use a standard monitor cable with a mac - vga adapter. Some of the Mac - VGA adapters will not work (as they ground out a pin that is used) but most will.
I purchased a few on MMVFleabay and was able to use them just fine but YMMV.
c-ya
Chris
c-ya
Chris
ty for all the help. partyharty someone posted about this vga adapter : http://www.clubmac.com/clubmac/shop/detail~dpno~29465~name~MAC-VGA+Adapter~mfg~F3H1381.asp
is this one like ur talking about?
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- nView Panel Help...anyone?
