Alain Dupont said:Sherman,
...have used a few in amplifier and power supply's in my Class A amp and they are of good quality...
Give it a try, and keep us informed, look to the noise floor.
Regards.
Alain.
motherone said:Go for it. I've used generic metal films before and they work fine.
...if you need resistors with more than 1/4 watt power handling, you'll have to go for rat-shack's carbon-film or metal oxide resistors instead.
For very good coupling caps search for North Creek Music
They have 2 series...
Regards.
Alain.
Sherman said:
Alain,
I checked North Creek Music and found the caps. One was more expensive than the Auricaps I was thinking of using the other was a bit less.
I'll probably stick with Auricaps but I'll definitely be looking more closely at North Creek's speaker systems and kits! Thanks for mentioning that site.
