has anybody had an issue with using a light bulb in series for current limiting on an amp that has a NTC thermister in series with the incoming AC power.
I have a 200W linear bass amp, in an Ampeg BA115HP. It had a shorted opamp that I was trying to isolate, and though I could leave the preamp board disconnected to see which opamp was causing the short. But my 16V zener diodes were on that board, so my +/-16V went to +/- 50V. ooops!
So i replaced the mains FET transistors, and decided to use the light bulb limiter. But as I ramp up the AC voltage the light bulb gets bright, at around 30 vac and gets getting brighter. My +/-50V buses are clamped at +/-4V as if by design?
I can't find anything wrong. The output from the transformer is good with no load. But i noticed a big black NTC in series to limit the in rush current. Probably a good idea since the 1st filter caps are 5600uF each.
But I noticed the NTC thermister isn't getting hot. Just slightly warm. In that state it still has a 5K resistance, so perhaps it is limiting my voltage?
I am going to try and take it out of the circuit, but I don't expect it to matter.
Any ideas on what else to try? I have almost no voltage across the 0.33 ohm resistors in series with the main power transistors, so I don't think my amp is causing the high current draw.
Here is the schematic.
115b by Dennis Kelley, on Flickr
115a by Dennis Kelley, on Flickr
