Now many hours does a stylus last?
I have been trying to find some kind of estimate on this. I am looking at several used cartridges that say they have been used 100 to 200 hours. I know that an exact answer is impossible, but I am wondering what the normal range is?
When the BBC used Decca cartridges
for broadcast quality playback, their recommendation was an inspection at 500 hours and replacement at 1,000 hours
I've had a Decca professionally retipped that lasted 12 years of dailly use before it expired; stylus life depends on how well the cartridge is setup, how good the gear is you're playing this on, how clean your records are ( and not the least: how clumsy the DJ is! )
El Gippo
Resurrecting this 2 year old short thread, I wanna ask:
1. What is your experience of average life time for elliptical or exotic shape true diamond styli on well set up systems playing cared for record discs?
2. What to look for as early wear signs? Is a normal magnifying glass enough? I mean the size and grade of the one we could burn bugs by focusing sun rays on them when kids.😀 ...Well not all of us, I was doing that. Older I focused on voice coils.:hot:
I started hearing some mistracking after about 1400 hours on my AT 440MLa (Shibata/line contact stylus). Just enough to notice, but much more than that and you'll be doing irreperable damage to your records.
edit: I'll also add that I did NOT notice any changes with a magnifying glass. I still have the old stylus and could put it under a decent light microscope and do a side by side comparison with a ~200 hour cart.
Probably we need a microscope for that...Thanks for your info. So hark for mistracking after the first 1000 hours is the sure path.
Any other experiences with more mundane shaped styli?
I am not Sreten neither SY is,🙂 but I can tell that all the MM cartridges I had (high compliance) Stantons and Ortofons failed by suspension sag. My MCs haven't been used that much yet so to tell.
My Monster Alpha II, and Sumiko Blue Point, both died of tired suspension components - no evidence of damage to the tip of either cartridge. IIRC both were well beyond 2000 hrs by the time all magic ceased - neither collapsed, but were basically sounding terrible. "Why does my TT sound so bad?":devilr:
d2g, I have yet to actually see any of my styli look worn at the point when they're sounding terrible (I have a nice little microscope for this). And knowing what I know about suspension/damping materials (I'm a polymer guy by trade), it's far and away the most likely explanation.
Stylus wear is, IME, analogous to heater failure in tubes- much discussed, rarely seen.
Maybe some facts help this topic:
There are two different beasts of styli:
-the nude ones: means it consists of many diamond rods, fitted optimally oriented onto the cantilever (so hardest crystal orientation is used for longest lifetime). These are the good ones, which can be found on lots of qualitative cartridges like the Shure V15, Nagaoka MP50, better Audio-Technicas and many others.
Shure stated a lifetime for nude styli of about 1000h.
-the mounted ones: are small fragments of diamond where it's not possible to mount them optimally oriented onto the cantilever, as the crystal is inhomogenously grown. Are the cheap pieces for budget cartridges, some manufacturers however also use them for expensive ones (easy to hide as such details are regularly omitted in the technical description)
Lifetime is of course much reduced, depends also a bit on the individual cartridge. Since it's in principle low-budget gear manufacturers usually didn't give an estimate on lifetime.
On lifetime and exotic styli shapes: if the manufacturer is serious, he has also to keep an eye on record wear which increases if the contact area is too small. So either the contact area stays the same (compared to spherical shapes) or the tracking force is reduced so that the pressure remains the same. Lifetime should not be affected in these cases.
The aging of the suspension plays for some cartridges also an important role, however more for 10 years and older cartridges. E.g AKG cartriges from the 80ies are well known for dead suspensions, as are the Studio-cartridges of Technics.
Have fun, Hannes
EDIT: to check wear you need a microscope, look for shiny spots on the sides.
Thanks for your enlightening contribution. Do you think that if we don't hear mistracking we should not start to worry? Many things to know about, for this set up demanding, prone to deterioration, sensitive mechanical ancient transcription technology...THAT EATS digital home media for breakfast, sonic wise anytime. 😀
Well, if it's sounds ok, why worry 😀
Mistracking usually distorts high frequency sound, so easily spotted. Or if you have a tracking test record you can use it to see how well it tracks. However don't forget that at least some mistracking can be caused by wrong anti-skate settings (appears then on one channel only).
Have fun, Hannes
Wow, don't I feel silly. I need to work on that reading comprehension bit.
I have experimental evidence of plasticity in diamond, and there are numerous examples of plasticity in other hard/brittle materials such as sapphire. I recently co-authored a paper on examples of extreme plasticity in silicon, albeit at small scales. I've always wondered how exactly a tip wore, and I've really been meaning to run some serious simulations. Maybe I can get some impetus from this conversation.
The strange thing about diamond is that it's modulus can increase dramatically under pressure, i.e. the higher the triaxial compression, the stiffer it gets.
A good quality tip will have minimal tracing loss and distortion.
Well before it gets to the point of being so worn it causes
mistracking the treble performance will deteriorate badly.
As vinyl speed is much slower at the centre the groove
is compressed and far harder to trace accurately.
So you compare the 1st and last tracks on a side, when
the quality loss is unacceptable, time for a new stylus.
When your super duper line contact starts sounding like
an elliptical or your quality elliptical starts sounding like a
spherical your not damaging anything but it is worn out.
Cheap ellipticals are often near spherical, and sphericals
it is harder to ascertain this but the same principles apply.
The end of side quality deteriorates rapidly when too worn.
By the time it starts mistracking the end of sides is very poor.
1) ~ 1K to 1.5Khours fine elliptical, ~ 2K - 3Khours line contact IMO.
2) You need > ~ x 150 to see any tip wear, and its not easy :
http://www.micrographia.com/projec/projapps/viny/viny0300.htm
🙂/sreten.
