Novice Question! Running 4 speakers Marantz 2215
Hello. I am wondering if it’s okay to run two sets of 8 ohm speakers through this receiver. I have a set of PolkAudio shelf speakers, and a set of Advent Loudspeakers. These would be running in the same room. Is this worth pursuing? Will it damage the receiver? Any advice is appreciated!
Moderator
Joined 2011
The 2215 manual says it is ok to parallel two 8 ohm speakers per channel.
However, the different speakers will play at different volumes.
Make sure all the speaker phasing connections are correct.
