Hi, it has been a while since Ive used PCD. I loaded all my traces (frd and zma) and I have selected the type of XO I want and the values but I am seeing nada. zippo. Is there a common mistake I am making that wont allow me to se the response curves? Thanks.
On startup, you might see a "warning" across the top. You have to "enable" and then check the "yes" box. Otherwise, Excel is limiting the macros and summaries that typically run behind the scenes.
