Not Getting Accurate FRD and ZMA
I am using FPGraphTracer to get FRD and ZMA files from the pic of the graph and the resulting output is not accurate. I am having this problem with only specific driver "Fountek Neo X1.0" as it worked fine for other drivers.
Did you double check your axis settings? This graph starts at 1 KHz which isn't typical. Using your picture I was able to get the FRD without any problem, but I did have to color the impedance plot before FPGraphTracer could trace it. I attached the FRD and ZMA files (renamed as .txt so I could upload them).
A couple of notes:
- IMO the FRD really needs more information added below 1 KHz to be useful for simulations. My first approximation would be to add a -12 dB/octave "tail" starting at 1 KHz. Several free programs allow adding "tails", XSim is one.
- The graphs will look a lot different when displayed on a 20Hz - 20 KHz graph.
Hope this helps...
