Hyldal said:Can anyone guid me to an explanation on how to make a NOS 24Bit DAC. intead of the known 16Bit types.
Hyldal said:
Also If you can use the 16 upper bits in a 24 bit converter, then you have liftet the signal up above the worst noise and unlinarity in the converter. In other words cleaner signal.
Maybe somone can confirm my filosofi?
Hyldal said:What Dir wouldt you recommed?
I one would like to have more than one input, what type og switch would you prefere, passive, relay, active?
rtd said:As We cannot access the diagram anymore, who could tell me wich line has to be inverted from the DIRxxx receiver
