NONOS for my NAD-502 (I2S from MN6474)
Hello, i'v got one NAD 502 CD PLayer and im finding the way to obtain I2S data format to input in a NONOS DAC TDA1543.
The datasheet of MN6474 (DA converter on the 502) got at pins:
33 LRPOL LRCLK polarity selection pin.
"H" level; selects the left channel
"L" level; the right channel.
34 LRCLK pin. When the LRPOL pin is at "H" level, "H" level in this pin indicates left channel data input; "L" level indicates right channel data input. When the LRPOL pin is at "L" level, "L" level in this pin indicates left channel data input; "H" level input
35 BCLK Serial input bit clock
36 SRDATA Serial input data (digital) input pin.
41 MDATA Microcomputer command data input pin.
Some body can tell me how connect this to TDA1543, I thik that
PIN 35 to BCK (PIN 1 bit clock input on TDA1543)
PIN 36 to DATA (PIN 3 data input on TDA1543)
And who to WS (PIN2 word select input on TDA1543)
Thanks, and best regards...
