hi everyone, let me explain in a easy way what happened with my system. yesterday i took away the Rockford 500a2, Sony xec1000 and rockford PA2 from my car, to find the source of the noise, then i installed on a desk with 2 EV 10'' speakers and power up and the noise was present even playing a song. the installation i made is a laptop connect to the preamp PA2, this to the crossover sony xec1000 and then to the amp.
i started checking each component one by one and when i touched the chassis of the rockford 500a2 amp the noise gets louder and i get an electric shock because i was not wearing my shoes. i disconnect the amp from the crossover and connected directly from the laptop and the noise is no present.
minutes later i keep with no shoes and i change the amp for a rockford 500a4 the noise is present in this amp too and when i touched the chasis of the rockford amp and i get an electric shock and the noise gets louder.
one thing i noted is that when disconnected the rca cables that came from the crossover to the amp, i received an electic shock from the pin of the rca cable terminal.
in some shorts moments the noise dissapeared and the chasis of the amp and the pin of the rca cable terminal did not gives any electric shock
how to find the problem...
i think there is a problem on the power supply of the crossover that leave some current flow to the neg.
