I think is time for a new law, and therefore a new thread.
What is the law?
Don't use transistors that (used to) come in metal packages for audio.
That means no TO-5s, no TO-18s, and no (gasp!) TO-3s.
That means no 2N2222s, 2N2907s, 2N2218s, 2N2907s, 2N3904s, 2N3906s, 2N2102s, etc.
Why, you ask?
Because they are all lousy transistors, that is why.
These parts have been around longer that most any of us have been designing stuff. They are from an era when a breakdown voltage of 40 or 60 volts was hot stuff. They all have low beta, which means they have low gain. Which you need to eliminate the nonlinearities they generate.
In the 70's, power amp desingers discovered high voltage transistors with weird numbers like MPS-U10 and MPS-U60 had very low capacitance. This made them very desirable for the gain stage of a typical amp. Too bad thay had low betas, but they were fairly linear, and hey, back then we used tons of gain (and feedback), so no problem.
Today, they a lots of modern transistors with a small base region, which means they will have low noise and capacitance, and a high beta. These devices have breakdown voltages of 80-120 volts and are very linear. Their Ft is plenty high enough for audio, but not high enough to build 70 MHz IF amps with. (See earlier post on why not to use RF transistors. Come to think of it....most of them also came in metal cans.) These devices are made by companies like Toshiba, Rohm, Zetex, and others. They are out there, and not all that hard to find.
Now, as for TO-3s.........
I can't think of a worse package to try to work with. A senior engineer I knew used to swear everytime he was forced to use one. Blamed the damn military for coming up with them, and holding back the evolution of modern packages.
In the 70's all we had to work with was lousy, stinking TO-3's. And the parts themselves weren't much better electrically. Thanks to places like Toshiba, Sanken, Fujitsu, and others, we now have modern plastic packages that are much easier to work with. Plus, the parts are higher beta, more linear, lower capacitance, and more rugged. Don't believe me? Then why is Motorola ("On".....or whoever they call themsleves now) second-sourcing Toshiba 2SA1302s and 2SC3281s? (You didn't hear this from me, but the first few batches Motorola sold were rebadged Toshibas: they couldn't get theirs right yet. You heard this from my retired friend who worked there at the time.) So there should not be any reason to buy a MJ15003 or MJ15028 or whatever unless you have to fix some old boat anchor amplifier.
Speaking of lousy TO-3s and power amps.........
A dealer I knew was having troble back in the early 80's with a certain amp blowing up all the time. I was called in to fix the problem. The amp used 40 volt rails. The problem was that the output transistors were rated at 80 volts. At 25 degrees C., that is. Too bad the amp was much warmer that that.
I called the company that designed it and explained the problem. I suggested a better transistor with a higher breakdown voltage. Their response?
"Well, that transitor has a different slope in the SOA. I don't think it will work."
Appears as if they were smart enough to look at a data sheet, and even where to look. Maybe. Too bad they weren't smart enough to understand how to derate operating voltage as a function of temperature.
Guess what? They soon went out of business, and not a moment too soon. We made $$ fixing amps for dealers who couldn't get repair work done. They didn't come back after we finished working on them.
Let's see how much hate mail this generates.
Class dismissed.
What is the law?
Why, you ask?
Class dismissed.
