I saw this on the Edcor new product page, what would you use this transformer for?
EDCOR Electronics Corporation. CXSE25-8-150
Athos
Athos
here's another one
Softone Matching Transformer MT-72 & MT-128 for SEPP Amplifier
Pete, cathode follower output would be a bad idea since a cathode follower output requires the same load as an plate follower output.
Tinitus, the Softone is a "matching" transformer, actually it is not a transformer but an autotransformer, meant for better loading of OTL amplifiers.
Joined 2009
A tad off topic - but how does the quality of Edcor XSE OTs compare with Hammond
I think you need to compare with CXSE series, to get a fair figure
Joined 2009
No, I'm not looking for equivalent exactly. Let me rephrase my question. Hammond have two ranges of SE OTs, one is top-end, the other is their economical range. If I'm being stingy (which isn't unusual
) then I start looking for even cheaper options. Low and behold I find Edcor who have an even more economical option. But then I wonder if 'I get what I pay for' I must be giving up a lot of sonic performance. So I ask those who may know, do the cheapo Edcor transformers compare with the cheapo Hammond or are they totally crap ? agains, sorry for off-topic, but this thread got me thinking about Edcor for the first time.
Bigun, maybe take a look at both home sites, Hammond and Edcor, and compare specs on frequency responses
might tell you more about what kind of quality you are looking at
other than that, I think we better get back to the special low impedance trafos presented here
be it autoformer or gapped OPT
I suspect both are best used with "parafeed" OTL designs ?
Or maybe making a stronger OTL head amp into a small flea amp ?
If being "parafeed" I suppose such SE OPT could just as well be used with PP design ?
- Tubes / Valves
- New Edcor opt, what would a 150ohm primary be used for?
