Nemsis 4 ch ID smd U10 : A04
Hello
I'm looking for help identifying a 5-pin SMD component. U10: A04
The driver board is from a 4-channel Nemesis.
The problem is that the IRS20124 was replaced and a shorted output transistor.
When powered on, the audio output FET quickly shorts out.
Not have signal in pin 1 of IRS20124 without fets of channel output
I don't know exactly what you should have except for the output of the op-amp being the same as the input on pin 3.
With no outputs, the servo loop is open and the op-amp swings to either power supply rail. Closing the loop locally (the 1-2 bridge), allows the op-amp to see what it's looking for.
Do you have a limiter you could insert in series with the high-side drain to help protect the output FETs? A 120v incandescent lamp would be one of the better limiters.
Reactions: joselorenzo
Replacing the NE5532 solved the problem.
Thank you very much for the diagnostic method.
Where can I find more information on this method?
I only have a current limiter on the 12V input with a set of resistors with a 2-ohm impedance.
